cademan
Lunatic Member
I enjoy all the posts so far.
Just a couple:
The old addage goes, "if you only knew then what you know now".
With that said, at about 9 years of age, I also had a hot chassis AA5 radio I knew nothing about. Had it out and on top of its cabinet and decided to go take a shower. Immediately after that with hair still wet, I went back to it and touched it and got the shock of my life. The plug was probably turned the wrong way in the socket.
A few years later, found one of those GE tube amps that use the push pull 7355 tubes that gets mentioned here often and it had a horrible hum through both channels. Thinking it had bad output transformers, I measured them with an ohm meter and they were not exactly the same from center tap to each plate, so I threw them away.
Just a couple:
