My dad was a mechanic and had at some point acquired a Cat D9. So he had all these enormous 1” drive sockets, which I inherited. They used to make great paperweights when I had stacks paper that needed weighting.
Now they just sit in my workshop, being heavy.
The most common alternative use for super-large sockets like that that I see, is using them for bearing and seal installers. Find one the right size, and it can help in pressing a bearing or seal into place, without damaging the bearing or seal. Great for wheel bearings, especially.
I've also seen a huge socket, a threaded stud (high-strength all-thread) of appropriate size and thread, a thick washer, and a nut, used as a harmonic balancer installer. The all-thread/stud is important- as you want to screw it ALL the way INTO the crankshaft- using a bolt into the crank, can cause ripping out the threads, if there's too much load before enough threads are engaged! A stud/all-thread will engage all the threads- then a nut is used for the clamping/jacking action...
BTW: Speaking of using those huge sockets and breaker bars on axle hub nuts- Dad used to tell me about one case, where a mechanic DID NOT torque an AMC Model 20 rear axle nut properly, on an AMC Ambassador. The wheel DID eventually go on an extra-curricular excursion, separate from the rest of the vehicle...
Regards,
Gordon.
