davidro
Lunatic Member
G'day all
As I'm on the search for cheap affordable power amp for my AR-3a I notice a lot of amps don't bother specifying the output at 2Ω at all. Well you'd be lucky if they tell you what the output is for 4Ω actually.
If they don't specify the output at 4Ω that is it safe to assume those amps aren't designed to run 4Ω speakers like my AR-3a?
I'm actually somewhat surprised to find out specs of my modest NAD 3120 clearly state what its dynamic output at not only 4Ω (55W) but also 2Ω (70W) as well. Man that's one capable little amp.
But I've read where the Adcom 555II was stable under a 1ohm load.
