Some aluminium volcano I guess.....anyway apparently it was no reason to reject it at the factory and they just used a thicker layer of the hard transparent glue-alike stuff when mounting the transistor....
Although I took apart the whole amp for a refurb instead of troubleshooting the cause of some failure (which included the transistor mounted on the bad spot), the following is "proof" the practice of replacing the grease also prevents overlooking the fact a heatsink may not be flat
See the "hill" of some 0.3 millimeters which was hidden below a transistor at middle of picture, before it was filed and sanded away.
So before applying the grease, make sure the heatsink is flat(another opinion).
Wise move putting the caps back into the Les Paul. If you think audiophiles can be irrational guitarists take it to the next level.Without factual data the argument for capacitor replacement is opinion at best.
Here is a frequency response curve of a 1990s speaker with new capacitors. No benefit to replacement.
This capacitor still was working!! However it leaks hot gas from a hole in the polypropylene. Yes benefit to replacement.
These capacitors look OK but measure 0.6 to 0.5, in spite of markings 0.22. They are from a vintage Les Paul guitar that "Sounds Good."
??? Replacement ??? (I put them back in the guitar).
These capacitors had already been removed for other repairs (glue cleaning). I did not bother to test them, the pragmatic decision was replacement with new items of equal or better specs.
ie, not remotely accurate, but oh, so good.![]()
Thanks for the info restorer john, l guess this just goes to show that our ears care little for specification figures and response curves. I have had some nice mid range amps from the 80's that look great on paper but in reality are sterile, fatiguing and frankly boring.
Well, some people's ears care little for specification figures and response curves and that's why there will never be an end to this debate. It'called the psychoacoustic effect and never more prevalent than when we hear 'what we want to hear' ie an improvement following a mod or work done
Very true steveUK, but l would like to think l have fairly good ears (learnt music for many years). I can normally tell when an improvement has been made and also when no improvement has been made and will be the first to admit if many hours of work has amounted to nothing in sound quality improvement.
I was just saying that like with many things in life, figures/specs vs real world practical usage is often two different things.
it's a fact that e-caps age
they are Chemical based to keep the aluminum clean.
they are sealed but do dry out
I have seen rotted off legs, either the chemical or glue or just age.
I've found enough failed ones in "working, sort of" gear that there is no question that they are the weakest link.
if a recap makes no difference in sound, either the unit was still working well or your ears are not working well.
fwiw, a total recap does not make it sound stunningly better.
the difference can be minor unless the cap was totally failed.
if your source material and or speakers are lousy, a recap won't do much.
