Kreshna
...but I have to know.
Wait... Found an interesting article here. Yes, indeed, push-pull amplifier suffers from crossover distortion.
However, there is no mention about Class D suffering from crossover distortion. In fact, crossover distortion is said to be an intrinsic feature of class B. Does Class D amp really lack of crossover distortion? And if that's true, perhaps the absence of crossover distortion is what makes Class D sound sweeter than your typical Class A/B amp, thus earning it the (perhaps mistakenly named) "tube-sound" label?
It's also mentioned that a simple Class D amplifier has relatively poor damping factor:
If I recall correctly, low damping factor is actually desirable in driving highly sensitive, full range single-driver loudspeakers. Also, if I'm not mistaken, single-ended tube amplifier also has low damping factor. A Class D chip amp is a simple Class D amp, isn't it? Perhaps that's the reason why Class D chip amp is often used to drive full range single-driver speakers, while traditional Class A/B amp is almost never used in such situation.
Also, such low damping factor perhaps makes bass sound bloomy and flabby, which people (mistakenly?) associate with tube amp. Perhaps that's why simple Class D amp is often said to have 'tube sound'.
CMIIW.
That flat spot in the middle of the waveform is called 'crossover distortion' and is an intrinsic feature of Class B.
Thirdly — not finally, but enough for now — a Class-D amplifier has a relatively poor damping factor. The damping factor is the ratio of the impedance of the loudspeaker to the output impedance of the amplifier (it's a little more complex than that, but let's not get bogged down with details). In simple terms, it's a measure of how well the amplifier can control the movement of the diaphragm of the loudspeaker. A good amplifier doesn't just give it a push and hope for the best; it senses where the diaphragm is from moment to moment and controls its position. To do that, a high damping factor is desirable, and, as mentioned above, a simple Class-D amplifier has a low damping factor.
CMIIW.
