I'm asking this question because I'm working on a Rek-O-Kut K-33H TT with S-120 tonearm and ran into an issue. I recently rewired the tonearm with KAB SuperFlex Litz wires. I also replaced the headshell wires. The headshell for this tonearm is not a typical setup. It doesn't have round male pins. Instead, it has flat pins to which the headshell wires soldered. I used regular headshell wires and cut the female pins off one end and soldered the wires to the headshell flat pins. When I tried to install a cartridge one of the flat pins broke off flush with the housing, leaving no material to solder the headshell wire onto. I believe the stiffness of the headshell wires had something to do with the pin breaking due to the force applied while trying to install the cartridge. I was able to pull the headshell pin and spring out of the headshell from the tonearm end and I was able to solder a piece of the KAB tonearm wire to the pin then pull it through the housing. There is no way I could have used a thicker headshell wire and fit it through the housing. I then soldered a female connector to the cartridge end of the wire. The SuperFlex wire is so much more flexible than the headshell wires that I'm considering using it for all the headshell wires. It would make cartridge swaps and adjustments so much easier and I wouldn't have to worry about breaking the other headshell pins when swapping or adjusting cartridges.
Is there some reason the headshell wires are thicker than the tonearm wires that would make using tonearm wire for the headshell a bad idea? I understand the tonearm wires are thinner to allow the tonearm to move with less restriction, which makes perfect sense. The only reason I can see for thicker headshell wires would be for signal conductivity but since the thinner wires are used for the rest of the signal path, isn't this a moot point?
Thanks in advance for any insight to this inquiry,
Joe
Joe
