Records need 'Big Box' speakers with AlNiCo magnets and 12 inch minimum woofers.
I'm quite happy my setup of small bookshelf speakers and a subwoofer. I have the subwoofers set pretty subtly as I'm looking for a smoother, more accurate kind of a sound rather than a more obviously heavy bass kind of treatment. I find what I have works pretty well but even so there's the rare recording that I'll put on where I can hear a bit of a "jump" where maybe one part of a bass guitar run is mostly coming out of the bookshelf speakers and then a low note or two will be mostly out of the subwoofer. That jump between the two sounds weird and is a bit distracting. This happens pretty rarely (with only certain passages of certain recordings) but it seems like a bit of a disadvantage to this kind of setup. A larger floor type speaker that doesn't need a subwoofer is going to have bass that's somehow more integrated so that there's always a perfectly smooth transition from the upper to lower bass frequencies...Subwoofers sound great if you know how to use them properly. Placement and Cut off frequency are the key. It should only be heard when needed.
My cutoff frequency is set at 60 hz. My Bookshelves go down to 48 Hz .Frequencies lower then that are pretty much non directional. Phase adjustment does wonders. Pretty hard to tell where it comes from in my case. I do sit 20 ft from the system though. No complaints at all coming from this Bass player. Another Great thing about subs is the Headroom saved from the amp by not having to send power to the speakers for low frequencies.I'm quite happy my setup of small bookshelf speakers and a subwoofer. I have the subwoofers set pretty subtly as I'm looking for a smoother, more accurate kind of a sound rather than a more obviously heavy bass kind of treatment. I find what I have works pretty well but even so there's the rare recording that I'll put on where I can hear a bit of a "jump" where maybe one part of a bass guitar run is mostly coming out of the bookshelf speakers and then a low note or two will be mostly out of the subwoofer. That jump between the two sounds weird and is a bit distracting. This happens pretty rarely (with only certain passages of certain recordings) but it seems like a bit of a disadvantage to this kind of setup. A larger floor type speaker that doesn't need a subwoofer is going to have bass that's somehow more integrated so that there's always a perfectly smooth transition from the upper to lower bass frequencies...
If they're playing 800Hz or higher they aren't subwoofers, they're woofers.Subs usually play from (hence why note specific) 15-800hz Woofers are usually 30-1600hz. IMO Its the upper mid bass in woofers that make the transition seem smoother because they can play higher up in the frequencies. When I browse P.E. I noticed that the larger 10inch and up subs don't go past 800hz but the smaller 8inch and under subs seem to go high into the 1khz range and over. These subs that play the higher frequencies tend to blend better with bookshelves or Satellite speakers IMO. Also the smaller subs sound tighter and punchier then the bigger subs which could also be from the upper mid bass. This is just my observation.
If they're playing 800Hz or higher they aren't subwoofers, they're woofers.![]()
Subwoofers have been around for quite a long time.I must be old .. where I came from they were subwoofers when they were playing under 30-40hz ..
But that was back in the day when speakers had woofers ..and when I started there was no such thing as a subwoofer ..
you talking bout vinyls?
Note that AlNiCo magnets are considerably weaker than modern magnetic materials like samarium-cobalt and neodymium.Records need 'Big Box' speakers with AlNiCo magnets and 12 inch minimum woofers.
I think you mean vinyls. Nobody calls them LPs any more.Yes - LPs
I understand that it would seem that way, but this is audio and you have to hear things for yourself. Can you visit an audio store and listen to some good bookshelf speakers?I notice lots of members here have bookshelf speakers, mainly on stands! And I mean members often with quite high end systems and people who have been around the audiophile hobby far far longer than I have.
As a relative newbie as soon as I could afford to I got a pair of large floor-standers. Coz normally floor-standers have bigger and more drivers and therefore produce a larger more fuller sound! Don't they? Am I missing something here?
I've been under the impression bookshelf's existed as a space saving device. Capable of decent sound but not as good as floor-standers! But then I see larger bookshelf speakers on stands taking up just as much space as as any floor-standing speaker would!!??
I'm obviously under a misapprehension!??
