Mike Sweeney
Well-Known Member
I'm working on my 2285B getting through various bits and now it's the main amp. The transistors all work but the mounting was pretty sloppy. I pulled two (PNP and NPN) and saw that the silly putty was starting to dry out and get cake-like. So scrub and cleaning I go. I also put cleaner into the contacts of the mounts. New silicone free grease and new mica insulators and off we go. I did measure the HFE.. should be >20 according to the spec sheet and the PNPs are 60 +- 2 and the NPNs are 45 +- 2 So they look to be in fine shape which saves me 6 bucks a transistor.
yes, that lock ring washer is falling out from the transistor mounting screw. Having that come loose in this section would have been "exciting" So there is so much silicon compound smeared around, I think they applied it to the mica without regard to how much it extended past the transistor. The end result is there was compound all down the legs to the mounting connector. Not that hurts anything but it can migrate can cause connectivity issues.
People talk about the 70s as this mythical awesome era but this units were mass produced and have all the inherent issues of something mass produced or more because of how much hand work went into them at the time. Its best to take it apart and check it out before you have an issue.
I measure each one to make sure I didn't short something out in the disassembly and re-assembly.
