When performing your test.... Make sure the ambient temp and AC supply voltage is the same during all testing.....assure that it is dead air and just convection flow...unless the unit has a fan....
Also make sure the overall heatsink is clean before you start your test or just make sure you don't disturb any of the dirt/dust....
Measure the mounting screw torque before disassembly....the thickness of, viscosity of and air voids / cracks in the old heat sink compound. The type, quality and condition of the mica insulator or if uses another type or none.
Test the old grease and characterize its age verse the new grease....
Assuming the original goop ... I mean heat sink compound....was installed correctly in the first place....
The purpose of the grease is so that the thermal conductive material ( usually an oxide of type ) is held in suspension and "flows" into the voids in the surfaces of the heat sink, mica and transistor case. As the volatitive compound burns off from heat over time , voids form and overal thermal resistance climbs....
Remember that the co-effecient of expansion of the Aluminum, Mica and steel are all different. There is a shearing motion that occurs during heating and cooling....the transistor tries to wipe itself clean of the oxide and create an air void in the parallel axis to the Mica.... and the Heatsink tries to separate itself from the mica....
So how much degradation occurs....? If I was an ME...I would have done that thermal analysis.... Maybe I'll ask my son the ME.....
Or you can just freshen up that 45 year old heatsink compound if the unit has been used....
A similar problem occurs with head gaskets on cars with Al heads and cast iron blocks....
jk
Bah humbug. LOL.
It ain't that hard to do a relative measurment. Absolute accuracy, yeah, that's a bit more tricky but still ain't that hard.
Back to my question, do you have any source for empirical data that shows the effect of old/dried out heat sink compound vs. new? I've browsed around a lot and found plenty of anecdotes and theories but no hard info.
I have some older amps and may do my own experiment just to see, since I keep thin film thermocouples and other sorts thermocouples and gadgets (accelerometers, pressure transducers, etc.) on hand for work purposes, not unlike what you used to do.
If changing the compound improves the thermal conductivity, one would expect the transistor junction temp and possibly the case temp would come down a bit but the heat sink temp actually may go up a bit, yeah?
