Bill Ferris
Lunatic Member
Dayum Billy.
Those are the largest analog meters I've ever seen,
Yes Sir.
Them`s some big cyclops eyes on those amps !!
I`m kind of glad that their in the adjacent sunroom, though I never turn on the meter lamps anyway, the Mac faceplate LED nomenclature might be distracting if those big boys lived in the living room whilst watching a movie, or listening to music with no lighting engaged..
The original & primary reason that the big amps ended up in the added on sunroom, was before I purchased those "Mac Daddy Big Boys", their previous 240 volt converted high powered Crown amps with their fans made too much noise when originally sited in the living room, so it was necessary to remote them to the 1997 built sun room add on.
The house`s original outside two windows & door were retained after the sunroom was added for other reasons, and I could close off the living room from the 2 1,500 watt mono configured Crown amp`s fan noise, after taking a 4" hole saw and drilling wall pass throughs, utilizing 2 separate, and spaced apart( high level & low level) PVC pipe couplers that were caulked on both sides of the wall for passing the amplifier`s L/R input`s speaker, and power cables from one room to the next with fiberglass insulation packed in the PVC pipe after running the cables.
By that time, there was no room in the living room for the fan-less Mac MC 1201`s, when they were purchased in 2006, so they were relegated to the sunroom, which I`m happy with anyway, being watching meters is not important to me while running the system.
Thank you BigEICat for your interest, and compliment, Sir.
Must be an ethnic thing.
