Will a 230v to 100v Converter still work in the US
Jon Q.
I bought a Japanese turntable from the UK and it comes with a very expensive UK-JA5000HW 230v to 100v converter. Can I still use it here or does the input have to be 230v?
Thanks for any advise!
Jon
you need to drop from your local voltage to 100v .. so 230v wont work .from what i see the unit is a transformer .it might have stood a chance if it was a switchmode supply
See if the transformer has multiple voltage options. It may have an internal tap that can be changed. If not, you'll get 50v output if fed from a US 120v outlet.
Related, see if the turntable can be changed to run on 120v without the transformer. It may have the extra tap as well.
