woe is my Ortofon Blue stylus...
Roman Totale
Through unfortunate circumstances my Ortofon Blue cart has gotten itself a twisted stylus. Is there any hope for it - now I am only able to hear one channel.IMG_9F7E586578A4-1.jpegIMG_2923.jpg
It's totaled except for maybe one of the few retippers out there that try to straighten the cantilever, but that costs more than a new nail.
The Blue is a much better sounding nail than the Red but the Red will work as the cartridge body is the same, if you much find a less expensive alternative. There are also some inexpensive cartridges that could replace the Ortofon but might not sound as good.
The cartridge being the way the music gets started from the record, it is not a place I try to save money.
What turntable do you have, if you want suggestions on a different cartridge.
Thanks but it seems I am gonna be paying 2/3 the original cost of the 2M blue on a replacement stylus.
Yep, so much for the "replaceable stylus" idea, eh? But that's pretty much how it goes these days and the difference of a few bucks is likely going to steer the customer in the direction of just replacing the whole cartridge......
Is there no hope of re-centring it?
Re-centering? Oh yeah, you could probably do that but there are associated liabilities, some of which have already been mentioned but if you're willing to take certain risks, it could be done. The biggest risk is damaging your records, of course, and the only way you're going to know for sure is when you start hearing a lot of groove noise that wasn't there before, in other words, noise the stylus has caused by not being more precisely placed in the groove so as NOT to cause damage like that......at that point, it's too late and your records are toast.
So, I really understand your frustration, amigo, been there before and with a cartridge that costs many times more than what you have and "all I could say was ouch....." Might be a good time to have a look at some other carts if you have a few extra $$$ to play with. Knowing a little more about your system might produce some good recommendations for you to consider, and some might surprise you in terms of cost and the sound quality you would wind up with. As @cafe latte has said, you're only going to be good for about 300 hours on an elliptical stylus so why not look at one of the microridge stylii, such as the AT95MR for about the same as what you will pay for the Blue stylus replacement? Again, need to know more about your turntable, arm and phonostage to make solid suggestions.
Sorry you've had this most unhappy event......but, who knows, there may be a silver lining to this cloud!
My collection is too precious to risk an experiment. :)
Thanks. I guess I could test my 'restoration work' out on some expendable vinyl to see if it worked...Gotta be worth a try? Actually did I hear somewhere that I could fit a cheaper Ortofon Red stylus instead if I wished to save some pennies? Are they compatible perhaps? But you wanna know what's the worst thing about buggering up the stylus - it had had less than 20 hours on the clock.
OK, moving on from that tale of woe, I'll happily give you the heads-up on my current system:
Rega RP40 (essentially the same as the RP3 with the external psu, RB303 tonearm)
Audio Technica MP110 cartridge
Roksan Kandy integrated amp with phono stage
Polk Audio Monitor 50 Series II Floorstanders
Thank you for your sympathy at this...difficult time but I'd be delighted with any advice you could give me on where to go next audio-wise. Or indeed any views you may have on my set-up. Speakers too cheap for it maybe?
Thanks for your interesting input there. I had in mind to try it with the Ortofon Red Stylus funnily enough. I assume there'll be a noticeable difference against the Blue version but no compatibility issues. Here's a quick take on my system as it stands...
