Gary Indiana
Looks like you've done it before.Bahhh! Amateurs!
I like my video and technique better (try it!)
http://www.youtube.com/watch?v=Hq8jkEx7aiA
I like how you "help" the motor to spin. Thanks for sharing the expertise.
Bahhh! Amateurs!
I've found a couple of YouTube videos on cleaning LPs with glue.
This one is short (1:24 min.) and only shows application of the glue.
And this one is a little longer (4:34 min.) with a comment.
LPMike, tell the truth, how many times did you try before you got a perfect ring at the inside and outside grooves to post. I'm impressed. I use my VPI 16.5 which moves much slower, then I'm older and move much slower. But the clamp at the center of the 16.5 is great for pulling the dried glue off.
Um, does "Mario" have a female hand-model doing the wood-gluing for him?
My trusty assistant demonstrating “breaking the seal” on the edge with the plastic knife.
You are probably right. BTW, I have found that "wetting" the LP with alcohol prior to applying PVA increases effectiveness. Perhaps diluting the PVA with alcohol?Hi SaSi & thanks!
...My concern is that diluting certain PVA glues in other environments can lead to difficult peels. As always, PVA glues and applications environments can vary widely - so there could well be different ways on how “to float your boat”, here. But let’s also be clear - water will not aid PVA wood glue in penetrating into the groove.
Either that,or Mario has gorgeous hands......![]()
. . . I'm perhaps faced with a problem of greasy vinyl in some cases, and the dirt trapped in the grease isn't getting lifted.
The glue I am using ... I've found that most PVAs say 'fully set in 24 hours' ... and it does indeed seem that the longer I leave them, the better the results.
Oh joy! To have saved myself the expense of a Moth RCM! (If I won the lottery I'd get a Keith Monks)
Tomorrow I'm going to the local hardware store to see if I can get:
- a thin metal pole.
- lots of plastic spacers
and then bodge up a vertical 'drying rack' so I can get a good 20-30 records cleaning at a time.
Plus ... time to buy the 2.5 litre container of glue. I've run out!
edit to add: I just had a thought. Now, I can coat one side with glue at a time. But have to wait for side 1 to dry out before coating side 2. But ... what if I coat one side ... then put, say, a spindle adaptor on the platter ... which would raise the record off the platter ...? Then I could do both sides at once if the glue is viscous enough to stay on side 1...? Hmm
I will try this tomorrow![]()
Hmm.
Although the theory seems sound:
... in practice, the very low viscosity of this batch of PVA may make this a bit of a mess ...
I wonder how I can thicken up PVA glue ...?
