cfinchrist
God bless America.
I've never tried plug improvement, but I know my line conditioner makes an audible improvement.
Exactly. If you take apart a run-of-the-mill 99cent outlet, you'll find brass contacts that touch the plug blades maybe at one or two points. Expensive outlets or hospital grade ones have larger contacts that make better contact with the plug blades. The contacts can be made of any number of materials that conduct electricity better and with lower resistance.
I did try an non-audio experiment once. I have an outlet in this room where I regularly plug in a 1200W electric baseboard heater. When I used a cheapie outlet, the plug and wire on the heater, as well as the face of the outlet, got real dang warm. :nono: I'm talking too hot to even touch the plug. I replaced the outlet with a hospital grade type and ran the heater. MUCH cooler operation, even after extended periods of time. Lower resistance, better current flow. If a heater works better with a good outlet (safer, too), then it isn't too much of a stretch to figure that audio equipment would, to some degree, get fed better.
Very little...as long as the contacts are tight.
One is highly cosmetically challenged, the other mint. Your ears will hear no difference, but I can safely assume that we would all choose the one with perfect cosmetics.
I did try an non-audio experiment once. I have an outlet in this room where I regularly plug in a 1200W electric baseboard heater. When I used a cheapie outlet, the plug and wire on the heater, as well as the face of the outlet, got real dang warm. :nono: .
I can argue that little or nothing is gained beyond a nice tight fitting connection such as a hospital grade receptacle, but our enjoyment of this hobby is not limited simply to what our ears enjoy.
Take, for example, two amplifiers, same make, model, price, and performance. One is highly cosmetically challenged, the other mint. Your ears will hear no difference, but I can safely assume that we would all choose the one with perfect cosmetics.
If it improves your enjoyment by all means buy the neater, cooler, receptacle (or any other gear). I'm definitely on the techie side of the fence, but I will still buy nicer (but not stupid) accessories because I enjoy the intrinsic value of owning nice things and taking pride in them.
You can argue under which premise exactly? Or is this just an assumption on your part based on common sense?
Who would be stupid enough to buy an a/c outlet because it looks nicer than the ordinary 99 cent outlet? You think a guy pays 79$ for cosmetics on outlets when you never see them once they're in use? Could there be a chance that this guy actually heard a significant difference to part with his hard earned dollars?
As you move up the ladder, it should be normal that the law of diminishing returns should apply. I do agree that hospital grade outlets should suffice in most applications. As I've stated, not all highly expensive components represent an upgrade. There are dogs at all levels. Listening to items is where the final decision lies no matter how it measures.
A healthy dose of skepticism is much needed and it seems to me it should go hand in hand with an open mind. Then a 'techie' can explore the possibilities as to why there are audible differences in components. This to me represents a good engineer/technician, people who base their professional opinion on facts and repeatable procedures and dare to devise new tests as the technology advances.
In audio, everything matters and everything that is in the audio signal path (this includes room acoustics) can/will alter the final outcome that reaches your ears. Much of it can be measured.
For those who want to go beyond the hospital grade outlets, I would be the first to say 'buyer beware', listen to the product and decide for yourselves if you consider this an upgrade. That goes for any component.
I don't think it has a lot to do with cosmetics, I'm actually naive enough to believe that most will upgrade to get drawn into the music.
AC outlets are one of the most over looked things in a stereo system and one of the weak links in a system too. When you get really good outlets for your (whole stereo system), its like taking a blanket off your speakers, its that big of a difference for some systems!
It's probably difficult to tread the fine line between healthy skepticism and an open mind, at least that's been my experience at key times in the audio world...
Here's a good thread on ac outlets.... http://forum.audiogon.com/cgi-bin/fr.pl?raccs&1065488253&openfrom&1&4#1
I have never seen anything like that going on there on audiogon but I don't go over there very much.A lot of us used to post there and we don't anymore. Post something negative about a product there and tell me what happens to your post.
Please take it with a grain of salt!
The forums that I would never ever post on anymore are the avsforum !!, audioholics !!, audio review forum !, ecoustics forum !
