justinjtim
Member
morning. I recently purchase a new pair of KEF Q300s to go with my kenwood kd650 tt and vintage Sansui Au555a amp. It's a system strictly for 2ch audio listening in the dining room. I love the sound of these new speakers very much improvement in my opinion over my old Bose 901 in sound clarity. My question is how much more could I get from these speakers bu upgrading my current amp? I don't want to spend much more that what I could get for this online plus a couple hundred bucks. Would they benefit from more power, keeping in mind I am not listening at real high volume. Just like clear great sounding music. Here are the specs for my circa 1970 Sansui amp. As someone new to this any ideas would be appreciated.
Form Stereo Integrated Amplifier
<Main-amplifier part>
Output power
Music power (IHF) : 85W (4ohm)
60W (8ohm)
Effective output : 33/33W (4ohm)
25/25W (8ohm)
THD 0.5% or less (Output power)
Cross modulation distortion (SMPTE, 60Hz:7000Hz=4:1) 0.5% or less (Output power)
Power Band Width (IHF) 20Hz - 40000Hz (8ohm)
Frequency characteristic 20Hz - 40000Hz, ±1dB
Channel separation 60dB or more (1kHz, Output power)
A hum and a noise (IHF) 100dB or more
Input sensitivity/impedance 1V (Output power) / 100 kohms or more
Load impedance 4ohm-16ohm
Dumping factor 50 (8-ohm load intensity)
<Preamplifier part>
Output voltage Maximum output: 5V
Output power: 1V
THD 0.1 (Output-power voltage) or less
Frequency characteristic 20Hz - 30000Hz, ±1dB
Channel separation (1kHz, Output power) Phono1, 2:45dB or more
Tuner, AUX: 50dB or more
A hum and a noise (IHF) Phono1, 2:70dB or more
Tuner, AUX: 80dB or more
Input sensitivity/impedance (1kHz, Output-power voltage) Phono1, 2:2mV / 50kohm
Tuner: 180mV / 50kohm
AUX: 180mV / 50kohm
Tape Play(Pin): 180mV / 50kohm
Tape Recorder(Din): 180mV / 50kohm
Sound-recording output (1kHz, input voltage) Tape Rec(Pin):180mV
Tape Recorder(Din):30mV
Equalizer Phono:RIAA NF type
Control Bass: 30Hz, ±12dB
Midrange: 1.5kHz, ±5dB
Treble: 15kHz, ±10dB
Loudness: +3dB (10kHz), +8dB (50Hz)
Switchpoint A low filter: 50Hz-8dB
A high filter: 10kHz-7dB
<Synthesis>
Power source 100V, 50Hz/60Hz
Power consumption 130W
Dimensions Width 395x height 127x depth of 278mm
Weight 8kg
Output power
60W (8ohm)
25/25W (8ohm)
<Preamplifier part>
Output power: 1V
AUX: 180mV / 50kohm
<Synthesis>
Weight 8kg
