Wow and Flutter measurements like you've never seen before! Maybe...
lsorrentino
Wow and Flutter
I’ve had a Vernier force sensor for educational use for a couple of years, acceleration and gyroscope. I didn’t have time to play with it until a couple of weeks ago, it connects via Bluetooth and can collect up to 1000 samples per second, here, acquiring the data, 5 minutes of data therefore 300,000 samples, on turntables with different technology and in different state of conservation I was able to make the most precise measurement of wow and flutter that I happened to be able to do and see.
The measurement was made on the turntable alone, so it does not include imperfections in reading and printing of the test disc and resonances of arm/cartridge system, the sensor was first balanced, the data is saved in CSV with its native app, I first examined them with LTspice, a program that I always use and that I know, then with a couple of Python scripts that I specifically created.
The most interesting things, which I was able to see are:
the spectrum of speed variation, with a resolution, at least by me, never seen
polar diagrams of speed variation
Have been tested:
Lenco L75 revised and lubricated.
Sansui XP-99 revised and lubricated.
Sony PS X555 ES NOT revised in the engine part.
Revox B790 revised and lubricated.
Who will win? I’ll tell you right away they are already in order of performance, from the first to the last.
In conclusion
Complete maintenance is also important for DD turntables, it doesn't matter what the service maual says, nor the fact that they lock the correct speed by turning on the "quartz locked" light. If you want the declared performances you have to disasseble, clean, lubricate, carry out service calibrations and measure before and after the treatment, to verify the effectiveness of the interventions.
I’m sorry I don’t have a belt drive turntable at hand, I have some but they have been stopped for a long time, I would be curious to measure a high-end one (mine are not), I think it would win at the test bench.
I now understand those who use the Lenco platter by putting the mechanics on a new base and changing the tonearm.
The DDs I measured are more precise in nominal speed but dirty the frequency spectrum more by “vobulating” the signal in some way. Is it audible? What is the acceptable limit? I don’t know, and I can’t make a direct comparison between these turntables of mine since they have different arm and cartridge, and then it would only be a subjective opinion strongly influenced by my preferences and beliefs.
The W&F weighting curve was made several decades ago, when technologically outdated devices were available, I am not entirely convinced that the dirt in high frequency is to be considered less important than that at 4Hz, the maximum sensitivity according to the IEC386. If so, the jitter of digital devices would have no importance, and it doesn’t seem correct to me.
It is possible, if I can I will try to do it, that these measurements can also be obtained with the gyroscope of the mobile phone, I will try sooner or later.
The sensor https://www.vernier.com/product/go-direct-force-and-acceleration-sensor/
The Lenco wins above all, its fundamental at 0.555Hz is placed at -70dB the highest in this test, but it is the one that matters and disturbs the least, consider that a 25 micron decentralized disc is enough to obtain the same "degradation". Close to 0Hz the noise floor rises, it is the speed which, being mechanical, is not very precise, but still within 2 points per thousand. Above 6Hz you see absolutely nothing.
Look at the dynamic range of the measurement, between the 0dB (I normalized to 33 and 1/3) of the continuous rotation and the noise floor there are 110dB!
Sansui and Lenco overlapped for direct comparison. This one is clean too, DD four coils effect is dominant, can’t understand what happens at half the freq rotation of the platter.
The Revox has several defects, the motor cogging stands out, there are no adjustments, trimmers to compensate for the asymmetries of the two driving circuits, nor to compensate for drift and differences that the Hall sensors could have accumulated over the years, hfe differences of power transistors.
I widen to 120Hz because the Revox, the only one tested, has a component at -90dB 111Hz, I guess the unshielded tachometer cables as the root cause. Not measurable with the means of the time, the German is the one with the most spartan electronics, the Japanese were much more cutting edge.
The Sony has never been serviced and it shows. It probably has an imperceptible ticking, an impulsive braking on the lap that the control immediately puts back on its feet. More precise RPM. Ticking evidence in polar diagram.
The results of the script that calculates weighted W&F and not of Lenco and Sansui, the Sansui was also measurable at the time via the tachymetric freq, the Lenco was not, it has performances much much higher than those declared.
The crowding of harmonics (however very low value) of the Sony that is slightly defective, the cogging at the frequencies that weigh more for the Revox. The Sony can be improved with the right maintenance, probably the Revox too by adding trimmers to balance the two motor control branches, that will be for another time. Who knows how much that spurious at 111.11Hz weighs, it's a kind of periodic jitter.
The gray circle labeled 1.000 (covered by the graph) is the speed normalized to 33+1/3, the inner one a thousandth less, the outer one 1/1000 more. Graphs are obtained by processing the average of 50 rotations.
Repeated acceleration and braking of the Revox are due to the geometry of the motor and the asymmetries of the driving circuit.
The Lenco simply brakes and accelerates smoothly during the turn. Would re-milling the bottom of the platter also remove this "defect"? Also note the slight positive deviation from the nominal speed.
The variations of the Sansui are softer and at low frequency, the 4 lobes are the 4 coils of the stator.
The Sony would win hands down over other DDs if I serviced it.
W&F RMS weighted​
W&F RMS linear​
Lenco L75
0.0071​
0.0328​
Sansui XP-99
0.0136​
0.0194​
Sony PS-X555ES
0.0157​
0.0182​
Revox B790
0.0229​
0.0246​
just out of curiosity, can you switch off the quartz lock on your DD table? I'm curious if that changes the spectrum. I've had people tell me that they have listened to tables that could be "unlocked" and thought it sounded better that way. I wonder if the lock creates some amount of cogging as it corrects for whatever imperfection in the speed.
I can try in the Revox, it has an option for variable speed in the UI
Very interesting, but why exactly two? From precession I will expect a more complicated figure, a "spyrograph shaped" one on a cylindrical surface.
Did about 200 revolutions and it never deviated from alternating those two paths. This was an SP-10MKII. Haven’t tried any other tables yet.
if it happens to be a thrust bearing design like a Garrard changer uses, the balls make a complete revolution every 2 turns of the platter. If its the more typical bearing where the pointy end of the spindle runs on a thrust plate or a ball then I don't know. That should be 1 turn per revolution.
Nope, in this case just a thurst pad without balls, or maybe just one in the middle, I don't remember.
Thats what I'd expect for most things honestly. The only things that come to mind with the other sort of design are record changers where the center has to be hollow in order for the stacker spindle's mechanical bits to pass through. Its a more complicated way to make a crappier bearing so there isn't a lot of demand for it.
Not surprised at all that the Lenco scores well. It goes along with my experiences.
So amazed that this "agricultural" construction from the sixties with a big hunk 'o motor, setting speed from the grid frequency, spinning a rubber wheel spinning a platter delivers such a rock steady speed.
I mean, who needs a direct drive or a fancy speed controller with gazillions of ic:s and other electronic wizardry?
I’m fan of the idler family, so I’m somewhat biased….however speed controllers are certainly a convenience which allows one to easily mitigate the effects of antiskate (AS) cartridge/tonearm drag on the platter.
One should set speed on tables, without automatic speed correction, with the needle dropped and AS set. Obviously during actual play the motor(s) and/or the speed control device are constantly reacting to the groove undulations (which @gadget73 alluded to above).
Unfortunately many that check speed and w&f with a phone app do so without dropping the needle, I’ve seen it done on YouTube many times by a variety of individuals.
Very interesting and informative post @isorrentino :thumbsup:
VR
Andy
I was more thinking about the servo mechanism's function, any over- or under-speed is compensated with a bump in the appropriate direction at whatever rate the electronics function at. If it happens fast enough in theory we'd never hear it but considering how much stuff we talk about on here that can be heard but not measured I wouldn't completely rule it out.
the drag of a stylus in a groove is it's own thing, and that actually may add some extra noise into the mix since the drag isn't completely stable. I'm sort of curious if that aggravates the servo mechanism's correction behavior.
I can try, my guess is no change, needle friction is too little load but, I can redo the maesure playing a high level signal LP. It takes 5 minutes. Good point.
The last experiment I saw showed no change, but that one wasn’t well documented, at least that I could find.
Also curious if those DD can be verified operationally. Only (good) ones I’ve seen exhibit those types of issues were broken.
The DD in this test, apart from the Sony, were in good working order.
Sony is working too but simply I didn't do any maintenance to the motor / driving circuit.
Verified how, as your plots suggest that they’re not? I’ve seen hundreds of polar plots over the years and ones that present as yours do were from very cheap units, or units that were confirmed broken, either by direct verification or inference from other polar pots of the same model.
Polar plots represents variation of 1/1000 of nominal speed that is in the nature of this devices.
W&F measures are absolutely in specs.
I still don't catch your point.
From the data I’ve seen it’s not the nature of DD aside from the dregs. Keep playing with polar plots and FM demodulated spectra and you’ll realize how little a W&F number tells you, in so far as to how many obvious issues it can mask. Helpful baseline if all else is operating fine, but not so much if it isn’t.
My data weren't FM demodulated, just the FFT of gyroscope data of the Z axis of my sensor.
I'm still thinking that I can not understand exactly how can you determine this plots are from not working units.
can the rpm data from the measuring device be exported to Excel ?
Logarithmic x axis makes it easier and more relevant to read
