Wurth brand capacitors seem to be good value for the money
62vauxhall
Addicted Member
No particular reason for this post. Just an observation or opinion.
Last month I replaced all small electrolytic capacitors in a circa 1973 Akai cassette deck. There were over 30. I tend to favor Digikey when purchasing such things but I confess I was soon dismayed after adding Nichicon and/or Panasonics to my cart. My tendency with buying small parts is ordering in lots of 10 so as to have a supply at hand if a future need arises.
Browsing Digikey’s assortment, I noticed there were Wurth brand capacitors in all the values I needed so I deleted the Nichicons and Panasonics and added Wurth’s instead. That wound up saving about 40%.
On the surface, it did not seem that going the cheaper route was settling for an inferior product. The Wurth examples I chose were either 2,000 or 4,000 hour service life and all rated at 105 degree temperature.
While removing old capacitors from the PC board, I saw that the bottom rubber plugs of some were distended. That made me think that a re-cap in this case was a worthwhile thing to do.
My choosing Wurth capacitors was prompted by being on a fixed income and reluctance to sink more money than necessary into a 50 year old cassette deck. The total of that Digikey order was around $32 CAD shipping included.
I was satisfied enough that I chose to perform a similar chore to an Akai 8 track recorder of similar vintage. I confined my choice to Wurth brand replacement capacitors except for 4 yellow jacketed originals which I believe means low loss or low leakage. For those I ordered Nichicon UKL series.
Although the total parts count was about the same, this order’s total was higher at $52 CAD. I guess some values are larger for the 8 track deck than for the cassette deck.
Since I have a few old pieces of gear kicking around that could likely use a refresh and retirement allows some time to do that, I see no reason to pay more than necessary for parts. I was not familiar with the name Wurth but what online reading I’ve done about that brand shows that it has some longstanding credibility.
over the last few years we have gotten the discon notices from Nichion...do they even make an EC under 3uf now? I have a lot of wurth, IC and Kemet now. panasonics you can still find and elna is about the only fine grade 1uf ECs left? But I have always maintained for the 14ish years I have been here, even GP caps on mouser today, are better and tighter than when the OEMs used then - a lot tighter quality controls, dead on balls values etc. I think if it comes from mouser or the key - go in peace.
i still have not tried wurth capacitors but i keep meaning to.
wurth makes a lot of products for the autobody industry, i got introduced to them in '98.
they've got a good rep in those regards
Been using Würth auto chemicals since vintage gear was last years model traded in, mid-80s. Good stuff.
Nichicon is only popular here because its HE and PW series caps were go to 20 years ago here on ak. Panasonic FC and FM were also mentioned. Those names took over. Not many had the guts to venture out to the Cornell Dublier or Kemet brands among others without the blessings of Echowars or one of the other known techs helping on ak back then that had mentioned the N & P brands.
Digikey and Mouser have probably done there homework and wouldn’t offer caps that were not at least adequate so other than the color of Würth caps they should be fine. Remember I said years ago I picked Nichicons by color, still might Especially when two are very similar and only ConradH would be able to test/select one over the other.
Here is the page about the different series Würth through hole radial caps for those that want to narrow down which ones are high temp, long life or low leakage.
https://www.we-online.com/en/compon.../aluminium_electrolytic_radial_thd_capacitors
@62vauxhall did you go with the free shipping option with Digikey?
I've bought some Wurth parts when they were the only option for some goofy value I needed. They worked. Not really sure what else I can say about them. The pricing is good but sometimes its enough cheaper than the next highest listing that it makes me suspicious.
The ones I've bought were nice pretty red caps. Maybe a little incentive for visual selection parameters.
I've used them for a couple projects, both through hole and SMT, no complaints. The Krell KAV-400xi that I'm listening to right now is full of them in fact.
I agree that sometimes they are almost suspiciously cheap...
I order project by project so they are well under the $100 threshold for free shipping.
Free shipping to US and Canada when the order is accompanied with a check. Of course, one needs to drive through the order process to get the tariffs and taxes so the check is for the correct amount. In the terms and conditions section
I got some pink ones. I guess they were less expensive because they only had the one coat of paint.
I do like the red/gold Elna Cerafine caps in my headphone amp.
i noticed a recent digikey order that had higher prices PLUS a tariff on several parts.
mouser was significantly cheaper with no tariffs. what's up with that?
With the last couple years of price changes, new shipments might have higher prices compared to a shipment received by D or M a year or more ago.
Chinese sourced parts have a tariff and both suppliers should be passing that along or adding it to the invoice.
I cross check some prices. Once there was a $25 per cap difference between the two but frequently they are the same price.
i was just looking at ksc2383. 100 for $20 no tariff on mouser...$22 + $2 tariff on digikey
but then go to ksa1013. 100 for $27 no tariff on mouser..$25 + $2 tariff on digikey
there's no consistency .. no pattern :dunno:
Started using them a year or two before Covid. Never had a problem with them and the price is right.
Makes it necessary to check a few items before placing the order, I guess. Does OnSemi make these in different countries and D got a shipment from China and M got em from Taiwan?
i got a production location change email from mouser recently.
moving from japan to malaysia on several units from onsemi.
that was dated august 2023...i didn't get it til jan 2024 :idea:
I usually just order from one or the other but in cases where I need parts that require an order to both for one project, I'll actually price compare every single item. Most of the time its not different enough to justify caring but if I have to order from both anyway, why not save a dollar here or there?
But, are they "Wurth" it?
[sorry, the Devil made me do it :)]
Seems to be a German manufacturer. And the German's make good stuff. Vince Shlomi says so.
Actual COO is China or Malaysia. The datasheets for the Wurth caps look good. I've used a few when my go to favorites (Nichicon HE, Panasonic FM) were out of stock. They worked fine and haven't come back.
