Ok so I'm stupid. Since I conflated the last two steps together I had the output at 15.5 instead of 30....Try adjusting your time-base and volts per division.
What your checking is the rail voltage switching point.Ok so I'm stupid. Since I conflated the last two steps together I had the output at 15.5 instead of 30....
Can you explain on my thread what the x-amp and it's setting does and if it is worth checking out you had a scope? That way if someone stumbles into it they will have it there to see?
Using both channel 1 scope probe and channel 2 scope probe you can get both + and - traces on the sine wave.Update: I got step 3 done, the right way, here is what it looks like:
View attachment 950523 View attachment 950524
Looks spot on from what I can tell!
APS output looks mint!
By the way I found that thread, I think it was just a bit misleading because he calls Step 3 "a confirmation" straight after describing Step 2, not incorrect technically but he makes them sound related when they are not.
The -13.66 can't be normal, both values should be +/-16.xx
Those points are the voltages (for the top and bottom halves of the waveform) where the waveform would clip in Class-A mode, and instead of clipping, the "surplus" part of the wave is reproduced by the opposite device. That's my understanding anyway. So what your result means is that for the bottom half of the waveform your amp would be switching to AB at lower power output than it should be.
I'd be double-checking components in the Turbo sections / everything relating to IC102 and IC103.
Hopefully avionic has something more specific you can check.
Sounds like a good plan. I kinda hope it works out as I have sorta grown fond of the class A operation during testing.Your schematic reading matches mine and everything looks in-spec, except for Pin1 on IC103.
I'd probably check if Pin1 changes when the Class A switch is on, and if not, check that R298=390K and R294,R297=10K by lifting one leg.
My rookie ideas end there for now, but maybe it'll give avionic something to work with next time he's here.
I would probably focus on sorting out the hum issue first since the Class A thing probably won't make any audible change unless you plan to use the function AND have a difficult speaker load, most speakers and average listening levels shouldn't really even drive the amp to its switching point anyway.
