Alonia
Member
I have a Yamaha A-1020 standing here, which has a phenomenon that I have not seen before. When you turn it on everything is normal.
The relay switches after 3-5 seconds and you think you can use it. Unfortunately it is not so.
In the left channel there is a fluctuating voltage at the box connector that goes up to 50V+ and 50V-.
After a long search I decided to change the capacitors in the left channel first to exclude them as a source of error.
I also removed the glue on the board, which was used to fix the capacitors.
Unfortunately this did not fix the error. As a second step, I refreshed all soldering points to exclude cold solder joints.
Unfortunately this did not fix the error either.
After systematic measurements I came to the following conclusion.
The collector of transistor TR211 should normally have 1.7V+.
Here I don't measure 1.7V+ but fluctuating voltage of 50V+ and 50V-
(Here is a fault in the service manual. The voltages at the collector and emitter of transistor TR211 are swapped)
At the collector of transistor TR209 there should normally be 1.7V- available.
Here I also measure the fluctuating voltage of 50V+ and 50V-
I have measured this in the healthy channel on TR212 and TR210 and there the 1.7V+ and 1.7V- are present.
Here is a list, which parts I have replaced:
TR211
TR209
D211
D213
C231
C245
C243
C239
C213
C255
Function (4) is the small board at the cooler with the driver transistors.
I use the board from the right channel, which did not fix the fault.
Probably I overlooked a little something, which could solve the problem
I have attached an excerpt from the service manual and marked where the voltage fluctuates.
TR211
TR209
D211
D213
C231
C245
C243
C239
C213
C255
