Dr. Ear
Two days ago I got an almost "like new looking" Yamaha A1-Amplifier, no scratches, perfect door hinges, no nicotine and almost no dust. The amplifier powered up and played for 1 hour or so, then the speaker relay suddenly cut off. No Natural Sound any more. Obviously a DC problem.
I got the A1 service manual and checked the adjustments. Power supply was 35V (perfect). Drive C Board: Left channel is OK but I am unable to adjust DC offset in the right channel. Once perfectly adjusted the value changes (± 50-100 mV!) when I press one of the illuminated buttons i.e. the Disc and/or Speaker button (the voltage on the 12V rail then drops to 11,5 V while 35V and 50V rails remain stable). You can even see this voltage drop because bulbs get a little bit dimmed.
There is also no chance to adjust the bias in the right channel. Value should be 7.4 mV but is 2,2 mV. When I try to adjust the bias the value jumps to 25 mV immediately (and vice versa back to 2,2 mV). The left channel is OK.
This afternoon I have recapped the power circuit pcb with no result.
Any ideas highly appreciated!
Attachment: schematics
