Yamaha C-4 pre-amp help
Do you have another pre-amp or pre-amp out?
I assume with this question you believe the amp is at fault, I agree since there is no voltage on speaker outs and the meter is not showing any signs of life.
Do you have a phone cable with RCA outs to connect your phone to the M-4 and see if the meter moves and if there is voltage on speaker outs?
Nashou
Nashou
I have a bluetooth receiver with RCA outs. I will try this and report back! I didn’t even think that would work!
Nashou
Nashou
I have a Bluetooth receiver with RCA out
: ELEVENKR
Bluetooth Adapter for Stereo Receiver - aptX HD RCA/3.5mm Output​
I’ll give that a try on the M-4 and report back.
: ELEVENKR
Ok I plugged in the Bluetooth receiver into the Yamaha m-4. Connected my phone by Bluetooth. No levels indicated on lights and no AC current detected on speaker outs when playing something.
I think that the Bluetooth receiver should go through a pre-amp because it outputs a line-level analog signal. I don’t have another pre-amp so I will have to brainstorm how else to test this just in case.
Sounds like I need to regroup and start evaluating the M-4 in parallel.
If no meters and no AC then most likely the M-4 is faulty. when you turn that on do you hear the relay click?
PS: your BT device had volume so it basically is a pre amp
Athanasios
Athanasios
I definitely hear the relay click on the M-4. Speaker button lights turn on and off. And I see a flicker of audio level lights when I turn the M-4 on.
did you adjust the volume on the BT unit when it was connected to the M4?
And you are using the Left and right Audio outs on the BT unit right?
Do you have audio cables that can go from your phone to the amp?
Make sure your volume on the phone is all the way down and slowly raise the volume.
Yes I adjusted the volume.
I am using the left and right audio outs on the BT unit.
I don’t have any audio cables that can go directly from my phone to the amp right now. I’ll do my best to get the right stuff and try this.
I just reread your original post , and now realize you have T-1 tuner.
This has a variable out put !!! you can use that as a source to the M4.
On a Yamaha T-1 tuner, the variable output volume is controlled by a small thumbwheel located on the bottom of the unit near the front center. [1]
Adjusting the Output
    • Locate the thumbwheel: Look underneath the front edge of the chassis, right in the middle, to find the protruding edge of the volume attenuator
      • Connect correctly: Ensure your audio cables are plugged into the Variable RCA output jacks on the rear panel, rather than the Fixed outputs. [1, 2]
      • Turn to adjust: Rotate the thumbwheel up or down to raise or lower the output signal level, which is helpful for matching volume levels with other audio components during A/B testing. [1]
      • Athanasios
      • Athanasios
I will try this!! I’m also wondering if I can connect my c-4 to my bass guitar amp. Using some rca to 1/4 cable if that exists just to confirm C-4 is working.
you could connect the C-4 output to an input on the kenwood , have to volume of the C-4 all the way up or past 12 O'Clock at least .
Or if you have a RCA to 1/4" phono to connect to the amp you can check one channel at a time with the guitar amp.
Athanasios
Look over the solder connections for the RCA input jacks on the little circuit board of the M-4. Make sure the two cables are properly plugged into the amplifier assemblies.
Athanasios
I tested the c-4 on my bass guitar amp with an 2channel RCA-1/4 cable. It works great!
I am very grateful for the advice from all of you!
Moving on to figuring out the M-4 problem.
Check the amplifier input plug-in connectors are properly seated to correct connection on the amplifier assemblies. :thumbsup:
Ok, the M-4 looks like it’s never been opened. Very dusty. The RCA connections look ok to me right now. I’ll dig more. I found one of the 500mA 250V fuses with a broken wire.
