UPDATE
Wow...it has been over two years since I restored my Yamaha C-70. It still plays great and I use it almost everyday as it is in my main work office. It is paired with a Yamaha M-85 power amp and a pair of NS-500M monitors. I change out the source equipment fairly often but my turntables are all Bang & Olufsen linear types. Either the BG400x series or the BG800x series since I primarily restore those types on the
Beolover Blog.
After about a year my C-70 started developing a switching issue with the Parametric Tone Control (P.T.C.) selector. Sometimes one of the channels would drop out. After exercising the switch control a few times it would always start working so a minor nuisance.
A short while ago another Yamaha C-70 owner contacted me and had the same problem. I told him I thought the problem was probably one of the yellow, 24VDC relays inside the preamp. Luckily I dug in to check that and to my surprise I had missed during my original restoration the fact that the P.T.C. controls are a solenoid operated switch (SW503) made by ALPS. Several of the C-70 manual operated switch are ALPS devices and look similar. However, SW503 is solenoid operated and controlled by the Tone Control front panel switch.
Looking at the schematics then inside the C-70 I located the SW503 switch that is causing the problem.
I removed the ALPS solenoid switch so I could take it apart and clean it.
You can see visible oxidation on the contacts. Nothing a brush and Deoxit can't cure.
After removing the moving pieces of the contacts though I saw how flimsy they are. I'm sure my cleaning and reassembly will fix the switching problem but how long will it last? I don't want to come back and repeat this process.
I decided to search for replacement switches or possibly better contacts. To my surprise I came upon a post on a reel-to-reel, Teac repair web site. The repairer had a similar problem to me with his Teac tape deck and the faulty switch was an ALPS switch that looked identical to mine.
The really cool part though was that the restorer had built a drop in replacement part for the ALPS solenoid switch. The replacement part uses individual, sealed relays instead of a solenoid driving a set of mechanical contacts. The replacement part should be more reliable and a heck of a lot more durable.
Here is the replacement switch next to the original ALPS switch.
The replacement switch is designed so the original ALPS metal cover can be re-used. However, the cover is not necessary as everything on the new part is sealed.
I preferred to not put the original cover on and just go with the part as I received it.
There is the part in place in my C-70. You can order your own replacement SW503 part from Kurt Jacobs via the email address shown above in the photo.
I am happy to report that this replacement switch works great and my C-70 is back to full operation with no problems whatsoever.
