Hifibythekg
Have done a lot of work on this preamp and am starting a fresh thread because several faulty components have already been replaced or repaired and am hoping it may now be much easier to isolate and identify the problem.
The issue:
Hum is present on all inputs.
-Playing vinyl on Phono 1 and 2, the hum is present BUT, despite the underlying hum, the audio is super clear and dynamic and evenly balanced on both speakers.
-When the Cartridge Load switch has ‘100 ohms’ selected the clear dynamic music is reduced to a muffled/bass and overwhelmed by the hum.
-When MC phono input is used only the sound of “muffled/bass and overwhelmed by the hum” is produced and turning both Cartridge Load dials makes no difference to this muffled sound quality. At no point does the clear music (as produced when MM Phono 1 and 2 are utilised) come through.
Repairs to date.
Full disassembly and servicing of:
(A clue? When audio is playing there is some bleed through to the other inputs. Feels like about 10% of the volume bleeds through.)
The issue:
Repairs to date.
- Wafer switches.
- Cartridge Load switches
- Reflow of solder and checking for solder bridges on all boards
- Replacement of eight 820 ohm carbon resistors that appeared to have previously suffered heat damage.
- Power circuit board
- Flat amp board
- Tone / headphone amp board
- RCA jack board checked and solder reflowed.
