Hifibythekg
Oh, ok.
Thanks for letting me know.
Appreciated
Appreciated
If... I should fail to find the cause of the hum... is it likely that a good audio repair technician would be able to readily locate the source? Is there any equipment that they use that makes tracing it fairly straightforward?
Thanks, so...
Is there any GND connectors on the Amp and if so is the C4 GND connected to it?
- NAD has a GND. The C4 GND (next to the Phono RCA’s ) is not connected to it. Should / Does it need to be?
If not GND connector on amp can you try to run a wire to a chassis screw on the amp case?
- Could run a wire from GND to GND on each amp. Can do this tomorrow. -
Should I just check the fuses, any visibly damaged components, and try switching on?
Or is there something else I should do first?
There are no " diode strings" or what ever your referring to on any heatsinks within a C-6 or a C-4. Just regulated power supply " pass " transistors on the heatsinks. Unless your referring to VD1212 varistors. Which are in close proximity to the heatsinks.shorted diode strings (on the heatsink).
Thanks guys.
So, have reconnected the blue wire and when power is switched on nothing happens.
No lights, no clicks or anything audibly or visibly upsetting..
Have checked all the fuses with DMM on continuity and they didn’t blow.
Can’t see any obviously damaged components in the PSU area near to the power switch.
What to do next for fault finding?
