Yamaha CR-1000 help needed
Hi. Well, I started to measure the fusible resistors as discussed,
So I measure on board:
FR801 and 802 - 68ohm (with some variations 67, 69)
FR803 - 481,2 Ohm
When I was measuring FR804, the part inside the cloth (I believe resistance R820) has burned at that moment, smelling and smoking. (See pic)
I then turn it off and am going to remove the board and not sure if should change that resistance because I am not sure if there is somethng that might cause the problem and do it again.
I believe this was probably my stupidity, because I had removed the screws that fix the board to the chassi, so that I could push it towards me a little more and I am thinking that probably some contacts could have been touching the chassi. :whip:
Although I am not sure. Yesterday the amp was connected much longer and nothing has fried.
I am sorry guys. Another problem to check.
I have been measuring the fusistors out of the board and they read as follows:
FR801 - 4.0 Ohm
FR802 - 4.2
FR803 - 0
FR804 - 47,2
FR805 - 4,3
FR806 - 4,3
FR807 - 10
FR808 - 222,5
R813 - 481 Ohm (should be 470 Ohm 30mA)
R830 - 10,2 Ohm (should be 10 Ohm 220mA)
I can't find a substitute for the fusistor at 22Ohm 150mA. Does someone can help me track this part or a substitute so that I can look for it and order it?
Thanks
Fusibles fail open, suspect this should be "OL" on your MM. Service manual has this as 47ohms 0.5W.
Would explain whu +/-50 and +33V supplies are down.
As a temporary measure you can use a flame proof metal film, 0.5w
Thank you very much. A transistor was also dead. 2SC1061.
The FR803 that reads 0 Ohm, in the board says 22Ohm 150mA. Please see picture. What part should I change it for?
Thanks
Hi. I should have gaved you some updates. Mainly to the friends who so much helped me. I haven't gave any update because I am still waiting for parts.
I had to order the fusible resistance from france and has not arrived yet. Also, I ordered several nichicon capacitors that I am still wayting for arrival.
Will post any feedback when parts arrive.
Thanks
Hello
?? You probably do not ask the right people !
After a long wait the capacitors ordered from nichiconcapacitors.com have not arrived. They didn't know what happened but they refunded me with the payed amount.
That is a job for later when I can find the parts. If the guys from @clinic-audio or any one that sells them in europe have good brand capacitors please MP so that I can send the list. Including the 100000uF ones.
Anyway. After replace the resistance everything was working perfect. Its a beutifull piece of gear.
Once again I would like to thanks the members that helped me tirelessly.
I am now rocking again.
Will start my other project now. A revox B780.Will open a new thread because I am at Yamaha and it makes no sence to go from here.
:beerchug::thumbsup:
