Chalkboard
Member
Is the TP1 reading conclusive, leaving no need for further diagnosis? If so, I will have to reluctantly begin the search for a working 1040 (or 840?,) to harvest the chips.Most probable cause of this is a failed output "power pack", Yamaha IG02960 or Sanyo STK0080II. You could remove it and verify that the receiver will then come out of protection, but going further than that goes beyond the realm of simplicity.
The unit, other than the dim meter bulbs, has always worked without issue, while ignoring the cleaning of inputs. The only thing out of the ordinary in its history took place after our move. I had the bright idea to use a power conditioner (it had also been in storage) upon start up, given I didn't know the condition of the new house electrical. It is an action I obviously regret in hindsight, but testing of the conditioner and the suspect outlet later showed nothing out of the ordinary. However, I continue to blame the conditioner, though it is most likely coincidental.
Assuming I find a working parts unit, shouldn't I be wary of what caused the failure? The expense of working parts units somewhat limits random parts swapping. Would a startup power surge ignore everything else in the receiver and just take out the chip? There was no smoke, sparks or popping of any kind, just a quiet protection light.
I sincerely appreciate your comments.
Bob
