Peter S
Member
Hi Keneye and avionic;
I have a CR-220 that had both output transistors shorted on the left channel. Both were replaced, one driver transistor was split in half, this was replaced. The other driver was tested OK in circuit. All transistors and diodes for the left channel test OK in circuit, but the left channel still slowly (take about 5 seconds) swings to - 22 volts.
I removed both outputs for the left channel and output still slowly swings to B-. (with no speaker connected) . The right chan plays fine, tuner section is working normally. Could this just be a leaky cap somewhere in L chan amplifier section?
