J57LITTLE
I've definitely heard of this issue and I thought about it, but it often affects performance on the right side - the tuner and inputs. Fortunately my inputs are strong and the tuner is surprisingly working well.
Where I did fine a problem was with the offset pots (VR701 and VR702). Let's face it, they were $0.02 each when the receiver was built and were designed to last a year. They were flaky when they were new, but 43 years later, they're a real challenge. Even so, after the third attempt I think I found a stable notch at under 3mv on each channel.
The good news is that I got the Yamaha CR-640 working and it has been working without a shutdown now for several hours - and it sounds great. Sine waves are perfect on the scope, with the right channel showing just a tiny bit more gain than left. In either channel I have huge output, but even at 100% into dummy loads I could not see any breakup on the sine waves - very strong performance at high listening levels for sure. I measured 26ma on the right at the same time the left was putting out about 23ma, so I'm calling this good. I really like the warm sound from this receiver - almost tubular in nature. And cosmetically it looks good, all the bulbs work and the phono section is crankin' just fine. I let Pink Floyd Dark Side of the Moon Track 5 (Money) confirm.
Thanks to avionic and ecluser for all the help. We got it!
