Hoping someone might have some sage thoughts on a CR-800 I've been struggling with. This unit had no sound when I got it, but I have since worked through to almost bring it back to life (with much appreciated guidance from avionic last year).
I have replaced fusibles and recapped the PB, main amp, EQ, and pre-board. I cleaned/worked coupler switch, disassembled function selector to clean, and have cleaned speaker selector.
Have great sound out of Main In, so have been focusing on areas ahead of that board. Had great sound out of R channel via aux and phono, however L channel was very faint. (Measured ~49VDC to EQ and pre boards.)
Switched original transistors on EQ board (R to L, L to R to see if they were the issue) and then got faint sound out of both channels. Replaced transistors on EQ and pre-board (ksc1845 for 2sc1345, ksc2690ays for 2sc1166) to be safe and still faint R&L channels. I even put back in the original 1166's and same result.
I've been trying to track down if I have a grounding issue, but have come up with dead ends. I don't see a solder bridge, yet, and have been able to test continuity across boards via ground. My brain is racked and feel like I'm overlooking something, but can't figure out what. I greatly appreciate any help.
Thank you!
Thank you!
