Posting here also for visibility:
I recently acquired the unit with unknown functionality. After doing some testing I was able to fire it up, but it had no sound from any input.
I have a relay click on power on, lights work, and was actually able to go through and set bias and offset. I cleaned the controls and coupler switch in the back but still no sound. I finally did a test of the main amp by turning the coupler off and connecting to Main In--was able to get sound through the speakers this way. So, I'm thinking something on the pre-amp is preventing any signal from getting through. Nothing appears bad/burned, solder connections appear okay, etc.
My question is where should I even begin on that board? Is it just a systematic check of all components or does someone have some tips of notorious culprits? Am I even headed in the right direction? Haven't checked power supply but, right or wrong, I hadn't considered it as I had lights, power to the main amp, tuning meter, etc.
Any suggestions are greatly appreciated. Thank you and Happy New Year!
