I have a CR-820 that I picked up a few weeks ago. I've since replaced the lamps and sprayed the pots with Deoxit/Faderlube.
Today I noticed that the Input select switch seems to be dirty, left channel intermittently cuts out on AUX. In the past the mute button has also seemed to stick on one channel. What is the right way to clean these two parts? Can I just spray at them or is there a specific part I should aim for or avoid? Is faderlube or deoxit better for these two parts?
Another small issue I noticed is that adding an antenna (read: speaker wire) doesn't seem to increase my signal Q but that may have to wait for another post unless there's a common issue in the tuner that someone can point out. I have a Kenwood tuner that shows a clear difference with the antenna connected vs not but I can't get the same on the Yamaha.
