Ok.No.. Just make sure you have good solder connections when you re-install it.
Post a photo of them..
Just wanted to verify there polarity..Here is a overview of the filter caps.
With an analog multimeter. One test lead to the metal arch and the other to the pin.
SS-3 - Red test lead to metal arch, black test lead on pin on diod for continuity.
SS3R - Black test lead to metal arch, red test lead to pin for continuity.
Reversing the test leads on both gives no continuity.
Hope this makes any sense.
Ok, well since the e,b is not centered on the chassie, can they be mounted in any other way? It will not fit the holes for the screws. But I will check!!Check that the transistors are not mounted 180° out. ie. upside down .. This would allow the screws to contact the heatsink.
But.. those pins will bend.., well since the e,b is not centered on the chassie,
How do I check this? There is some resistance when gently pushing the transistor in tomthe socket.Check and see if the transistor sockets are not broken..
Remove and physically examine.. It only takes one of them to be bad.How do I check this?
