4seatPilot
"Broker"
Well we'll need a bloody long interconnect then .......
:lmao:
Good one!
sent from the 2nd galaxy with tapatalk
I acquired the M4.
just have a question for Avionic if he chimes in; someone pulled the two rear output transistors on one driver board and was running it like that. I was considering buying it before I noticed this. It was showing output on both sides and power meters working but clipping light wasn't working on channel with missing outputs. Is this worthwhile for restore or has the damage already been done? I know this is not enough of the picture to say, but it looks like it fell into the wrong hands.Avionic's has tested the M-4 at 150+ watts.![]()
The missing parts is a good angle to dicker a better price.If its working with 2 outputs missing now . It will work even better with a full complement. Most likely solve the clipping LED issue as well.just have a question for Avionic if he chimes in; someone pulled the two rear output transistors on one driver board and was running it like that. I was considering buying it before I noticed this. It was showing output on both sides and power meters working but clipping light wasn't working on channel with missing outputs. Is this worthwhile for restore or has the damage already been done? I know this is not enough of the picture to say, but it looks like it fell into the wrong hands.
Reguardless. You can not discuss monetary topics concerning your M-4 in this forum. Have Mods move your post to dollars and sense.Hi, All,
Just found this thread... as I was looking for M4 info.
The story...
I have one, bought years ago, but have not used it beyond a few test and the occasional power-up (with a variac) to keep the electrolytics formed. Of course it's flawless... I liken it to a "short thick wire with gain"!
The pea lamps in the switches failed (daft idea), so I replaced them with LED's in separate near-flush mounts below the switches... looks fine. I need to clean the input pots as one has a slight scratchiness.
I'm now thinking of selling it to make space (too many tube amplifiers!), so I need to get a valuation. Note to moderators: I am not selling it here!
So, more work to be done...
Cheers,
Roger
I recall saying recently... (perhaps even here!), that the M-4 is like a "short thick wire with gain"... adds nothing, takes nothing away. Can't ask more than that.
Cheers,
Roger
I run dual M-4's in my system. I love them. Both have been fully recapped with a few mods. They sound awesome. :thmbsp:
I would refer you back to the threads on it but it seems they are gone. But just a few I can remember was total strip done and repainted chassis, total recap with bigger filter caps, new RCA's jacks, New speaker jacks. There was more done but my memory is not like it used to be.Curious what mods? Thanks
Yes it would. That would put the load on each amplifier assembly to around 2 Ω.Would running two pair of 4 ohm speakers in fact be a problem?
Makes sense now. ThanksYes it would. That would put the load on each amplifier assembly to around 2 Ω.
No...Unless you want to exercise the protect relay.Would it be acceptable to run speaker output B to an amplified sub
Needs a low level signal. from a pre-out. Unless it is a speaker level input on the Sub amplifier.an amplified sub
