jmascarenhas
Member
Hello.
I have the NS-1000M (90dB) and the FX-3 (92dB).
I assume that with the same amp at the same volume settings position of the knob, the volume of the FX-3 should be higher due to higher sensitivity.
This doesn't happen with my speakers.
The NS-1000M play slightly louder than the FX-3 at same volume in amp/preamp.
Does that means that one of the speakers may be failing in the crossovers or there are other reasons for it?
They stand aside of eachother, so shouldn't be placement difference.
Would appreciate your help so that crossovers should be inspected before failure.
Thanks
Thanks
