Used 8 cassette tape cases for the 4 corners of the bottom plate to elevate it. Put weight on the bottom plate.2nd attempt... will find out tonight how it has held up after 24 hours.
Attempt to un/reverse bend the bottom plate.
use heat and weight.3rd attempt will be this weekend.
I don't know if there are many other 850's still floating around.it's just you and me here....
1st attempt was not sufficient
(you do see the problem?)
early on, this (shimming) was the 1st direction i took.The base of the 850 and 750 are not generic plastic, they're a composite and I wouldn't expect it to keep a bend... but maybe?
Have you tried shimming the spindle where the platter sits? That would raise the platter without affecting the rest of the mechanism alignment.
Clean those before you think to remove, they look salvageable!This is one side of the 350 bearings, upon disassembly. You can still see the balls.
Am thinking the bearing is simply squeezed in and can be pushed out.
This is the conclusion I arrived at after returning to the project late last night.I think you'd need a puller of sorts, to reach inside and then use to pull straight out. I don't think they were meant to be removed.
This is why swapping the entire arm seems to be the ideal solution.
