Yamaha P2200 Humming
Skylape
I recently got a Yamaha P2200 from a friend and it got an annoying hum right around 60% volume. After reading some of the comments, I decided to open the amp and try to replace all the cap. I am currently looking at the Drive Stage Board and I noticed a lot of unidentifiable capacitor. My question is how important is replacing all of these tiny capacitor? and if so, what is the method to identify it? Also, is there anything else I could do to improve the sound quality of my amplifier?
If the hum is present in both channels. I recommend looking at the power supply first. It would be common to both channels. What impedance are your speakers?
My Preamp/Sound card are Asus Xonar STX and I hook it up to a dbx go Rack. The following attachment is my speaker impedance. It said the impedance is 4-8ohm.
Might want to determine if it is your source first by trying a different one, before tearing into it. One test is to short the inputs of the P-2200 and then turn the attenuators up. best to monitor the o/p's with a scope (your eyes) when doing these tests.
I have 2 of them in for service right now, they are solid units. I will test the big ecaps, will leave the original ecaps in, since the owner was not too concerned about changing them. Check bias, offset. The original binding posts are junk and all need changing.
Im pretty sure it is the amp because it's still hump even when I remove the amp from the source. Only if I disconnect the input cable completely, the amp stops humping. Also can you elaborate more, Im pretty new to this.
For removing the source, I just unplug the cable from the go.Rack and keep the other end plug in the amplifier. I also use balance XLR.
