Perhaps cleaning the input attenuators. Or solder connections on said attenuators.if I play with the volume pots the hum is gone
Many thanks avionic, good to be here after a long while.Welcome aboard Roy
Here is the list of components that I have assembled to go with my vintage build the photo is of my profile on CanuckaudioI have a question and hope I can get some answers and input on how to move forward. I’ve been working on my vintage build for a couple years getting all the parts and components I need to complete my build. I’ve had a Yamaha P-2200 I bought new in 1978 and love it so I wanted to pick up another one for my build but I got bit but the big meter bug and have got carried away and before I new it I had
six P-2200’s and two P-2100’s all were in great shape cosmetically and all have since been shipped to a buddy and recapped where necessary.
Since the beginning of my build I’ve been purchasing all of the right components over the last 2.5 years to build a pair of JBL 4355’s and I’d like to use all of the amps to make it work.
So here is my thought process for the system
This idea is per side:
P-2200 through DBX 260 driverack bass
Then through my custom built charge
couple x-over run
P-2200 midbass
P-2200 highs
P-2100 u/highs
So my idea is to use the all 6 P-2200’s in mono for each driver from bass to highs
Same goes for the 2 P-2100’s for the ultra/highs
I read that I might need balanced transformer to turn them mono. Yes/no and what kind if I do
Thanks for any input given
couple x-over run
P-2200 midbass
P-2200 highs
P-2100 u/highs
Thank you for your helpTake this with a grain of salt because I'm not personally familiar with that amp, but this is what HiFi Engine says "The P2100 may be converted to a monaural super amplifier with an internal stereo/mono switch. This creates a transformerless balanced output, the speaker load bridged across the hot terminals of both channels." Sounds like it's going to be a sweet system. It'd be nice to see some pics when you get it all finished
again thank you DanTake this with a grain of salt because I'm not personally familiar with that amp, but this is what HiFi Engine says "The P2100 may be converted to a monaural super amplifier with an internal stereo/mono switch. This creates a transformerless balanced output, the speaker load bridged across the hot terminals of both channels." Sounds like it's going to be a sweet system. It'd be nice to see some pics when you get it all finished
couple x-over run
P-2200 midbass
P-2200 highs
P-2100 u/highs
Thank you amr2 I understand the power rating for all my drivers, but my sole purpose is to utilize all my yamis.A P2200 in mono for highs? It's more than overkill for home use...as well as exceeding the power capacity of the drivers. The JBL 2441 have a nominal power of 70 W and the 2405 only 20 W. Just my opinion
Thanks Chris and amr2So one thing that is worth noting here, is that it sounds like you are talking about bridging the amps. The term "mono" is somewhat ambiguous. Bridging specifically refers to using both sides of the amp together, with one side handling the positive voltage swing and the other side handling the negative voltage swing and thus dramatically increasing your available power over using the amp in stereo configuration.
Just keep in mind that there are some downsides to bridging. Because you are using both sides of the amp together, you are doubling your THD, your damping factor is cut in half, and each side of the amp will see a load that is half the impedance of what it's actually powering. DC offset also combines, which in a worst-case scenario, could cause two amp channels with otherwise acceptable DC offset to result in one channel with unacceptable offset, or if you get lucky, the DC offset could potentially cancel each other out, depending on the specific offset of each channel (which can be positive or negative).
Usually, none of those things are deal-breakers if you actually need the extra power, but it would be counter-productive if all you were doing is powering a tweeter or lower-power midrange driver. Likely the only driver that would benefit would be the low-frequency woofer, maybe the mid-bass woofer. Potentially run those drivers using bridged amps. The other drivers like the mid and tweeter, for each side, use one P2200 amp and run each driver from one amp channel. That would still give you 230w per driver, without the doubling of distortion, etc.
Where did you get that board ?I’ve Found The Vintage Yamaha Pro Amps To Be Very Musical And Great For Home Use. This Amp Is Part Of My Vintage Collection. It’s Been Completely Restored, A Soft Start Custom Board Was Added, As The Inrush Start Current Is High On These Amplifiers. Another Awesome Vintage Pro Amp For Home Use Is The, Crown PSA2 / SA2.
Soundcraftsmen MA5002A, Ashly Fet-2000M Are Also Great Audiophile Amplifiers When Serviced.
