That should not matter at all.Some of the watt difference is the voltage difference.
How did you get the tag off the face plate?
Thanks everyone!! It sounds nice, I like it
The tag is glued with double sided tape. This tape is thick, so you can use a cutter to start taking it off without touching the face plate. Once removed, clean the surface with alcohol.
It was my plan B![]()
