Yamaha PX-2 Repaired!!
vbmagus1980
Member
i shouldve done this a long time ago but the sole purpose of this thread is to boast on about how my PX-2 is finally 100% operational thanks to Professor Bizzt on AK.
For over 2 years the automatic functions werent working on the PX-2 so i shelved it until i ran into Bizzt and he told me he can replace the photo interrupters that were the cause of the PX-2's problems. So being in Australia and Bizzt in USA, i suggested sending the Sensor C Board (of which the photo interrupters are fitted on) to him, he replaces the interrupters, send the board back to me, i plug the board back in and away i go. He agreed, and now my PX-2 is alive for the 1st time in over 2 years.
Removing and re-fitting the sensor board was a piece of cake. No soldering required at all. Bizzt is very professional and helped me out in every way he could, i cant recommend him enough.
So if anyone out there has a Yamaha PX-2 or PX-3 that needs repair, hit Bizzt up and im sure he'll help you out if he can.
if you wanna see my PX-2 in action (not of the auto fucnction though 'cause i didnt need to use them in this particular video) then go here -> http://www.youtube.com/watch?v=OC44VztgGB4
Cheers
That was the problem with the PX-2 that I bought, got the sensor board from a PX-3 organ donor.
Cheers
Yes, Professor Bizzt has a PhD in Tangential Tracking. :yes:
Hi you guys!
Thanks a lot for your kind compliments. I do appreciate you both taking a moment out of your busy day to say good things about another person.
And if I may return the favor....
RDecartridge; you've been wonderful to associate with since I've known you. Your commitment to audio, conscientious and honest follow-through with your customers, and overall honesty is absolutely first rate.
vbmagus1980; It has been a pleasure helping you out. You were always upbeat, patient, and understanding, and your technical skills helped everything go well with your PX-2. Sometime I hope to visit Australia and meet some of the great people such as yourself there.
Thank you both, and may good things and good sound always find you.
Best wishes, Professor Bizzt
Any idea why these fail? It should be a pretty reliable component. Was there a bad batch during the PX's run? Can anything be done to prevent failure? Mine is from 79 and every time I press the 30cm button I fear it breaking.
This is what AK is all about! Others helping others and if more of this sort of thing took place around the world, maybe we could all live together in peace.:tresbon:
I am not sure, but when I called my contact at Yamaha and described the symptoms he knew right away what it was. Since repairing it with parts from a PX-3 donor I found three NOS parts from a box of parts I bought from a former Yamaha dealer. I also found what may be a good replacement in a currently available part. Details are on the shop PC so I will try and remember to post them later.
Hello everyone,
Back in November of last year I contributed to this thread: http://www.audiokarma.org/forums/showthread.php?t=308044
In it you will find the actual part I use to replace the failed photointerrupters. I now provide a service to repair these sensor boards. It requires you to remove the Sensor C Board from your PX-2 or PX-3 and send it to me. Removal and installation of this board is not that difficult.
The original Sensor C Board has unidentifiable slot type photointerrupters. There is a number on them, but no manufacturer name. I searched for the number on the Internet, but made no progress identifying this part. What I did was to exhaustively go through all the slot type photointerrupter datasheets I could find until I found one that was as close as possible to the original. The one I chose is very similar, but still requires modification to work in the Sensor C Board.
One cannot begin to understand the reason for failure of the original photointerrupters without first having the datasheet for that part, and that can't happen without first identifying it. It's possible that leaving a PX-2 or PX-3 continuously powered up might might take a toll on the life expectancy of the photointerrupters over time and that could be a contributing factor. From what I have seen so far, the photointerrupter's receiving section, and not the LED transmit section, fail.
Also, (and I should not have to remind an audiophile of this very elementary fact) you should always use surge protection for your system. You should also remember that detrimental surges can enter your system for any cable entering your home and connecting to your system, not just the power connection. A surge is not going to help your turntable live a long and happy life. It may not impact the photointerrupters, but it most certainly would impact something else in the circuitry. Also never forget and leave your turntable powered up with a towel over it as it will tend to overheat in this condition.
A PX-2 & PX-3 works great after all this is completed and should never malfunction in this part of the circuit again.
Peace and PX-2s
Thank you soundman2.
Peace... Yes, the opposite of obsessive compulsive domination disorder syndrome and a thing of beauty and unlimited dimension as well as a close friend of love from what I understand.
Peace, Professor Bizzt
