Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
Tried several places, first the blue wire that goes to the motor board screw from the main board. Then, the blue wire that comes from the power transformer to the main board.....
That is OK and expected that you will measure a high resistance, which is MUCH different than 0 ohms. A reading of 0 Ohms probably means a short, but a reading of some other is either internal resistances or external paths between pins. So back to my original question... when you measure pin 14 to Gnd, do you measure a resistance or 0 Ohms?
I was asking you to check to see if pin 11 (sorry typo on post #67) was shorted to ground by measuring the resistance from pin 11 to ground to see if it measured close to 0 Ohms. I asked to make sure that the signal trace from TR7 collector to IC2 pin 11 had a short to ground causing you to measure 0VDC instead of 11.6v. But it sounds like you do not have a short to ground since you measure a resistance. In that case, I would think that TR7 is bad.
Thank you for clarifying.....I kinda thought that was what happened which is why I included, later, the value for pin 11.
How to test TR7? How could that go bad when I did nothing remotely (to my knowledge, and that's questionable for sure!!!) close to it and sure didn't unsolder it or anything. Is there a way to test that component?
Does your DMM have a diode or transistor tester? If not we can test the resistance like diodes.
By the way, this might be an issue but might not solve other problems that you encountered, but needs to be corrected.
You will probably need to unsolder the transistor to test it.
I tested the TR 7 and got:
Step 1 (B to E): OL
Step 2 (B to C): OL
Step 3 (E to B): 0.684V
Step 4 (C to B): 0.678V
Step 5 (C to E and then E to C, switching pos and neg): 0.848V and 2.724V
So, it all checks out except Step 5......however, this was a test without taking the TR off of the board.
