What a callous and nasty response I thought in bed last night!!
Don't go back into the tonearm base trying to correct this.
Go through the checking/adjustment procedure, checking VR1 and VR4 at the test pin (note these instructions are similar but different for PX2) and adjust them per the repair manual (0V +/- 50mV)
If you then find that the arm doesn't come to 90*, go ahead and adjust VR4 until it does. I have done this in practice on PX2s and I also see a tech made a similar note in my copy of the repair manual that he set it to 300mV to trim it. (If you look on the circuit diagram, VR4 adjusts the bias of CDS sensor)
I recollect setting the cartridge down on something I put near the platter's edge, and being able to watch the correction angle of the arm change as I adjusted VR4, but remember, I was recently released from the NJ Home for the Mentally Enfeebled!
PS: it just occurred to me, perhaps check the two values and set them. See if it's OK>>DONE
If not, then while monitoring in tonearm down/tracking @90* position mV and adjust at the CDS for 0V +/-50mV, and see if everything gets right.
OR>the easy button.
OR>the easy button.
