georgedannyg
Well-Known Member
hi guys i just bought a yamaha ca 810 off of ebay and tuner i was wondering how this amp sounds and what you all think about this amp
Horsecrap..When used with efficient speakers 10 watts is plenty of power..Yes it will run hot..Its class "A" its designed to run hot.But will sound like heaven..Just Don't switch from class"A" to class"AB" or vice-versa with power applied this tends to put overwhelming current on switch or relay contacts.Don't use the "class A" switch, it is useless, the amp will get 140 degrees in no time and you'll get 10 Watts/channel.
That switch isn't on my CA-810. Maybe I have an earlier or later version...or there's some confusion about the 810.On the Yamaha CA 800 and 810 there is an "operation" switch in the middle of the unit. I don't know if other manufacturers offered this feature.
Resolution is too low to show. But in the middle bottom is a regular switch for class A.
On the CA-810 I believe they call it the "Mode Switch" for switching from A to AB.
