Bassblaster
Greetings. i recently got my hands on some 24V 300VA NO CENTER TAP transformers and i was trying to figure out what to do with them. i did some google searching for a 10A (capable) power supply. and after a while i found a schematic using 3x 2SD1047 outputs and an LM317 as the driver. i drew up this and i want a 2nd opinion before i order parts. The diode bridge will be externally heatsink mounted. Anyone see anything wrong with this setup? should i change anything? if all good i can start on a custom PCB.
