Chris Brown
Not sure if this technically counts as a "repair" but funny story none-the-less. I was about 7, trying to hook up cable TV in my bedroom at our new house. It wouldn't work at all. I traced the cable on the exterior of my house starting from where my bedroom was as it made it's way over to our main cable distribution box (where the cable came in from the street). There was one spot where the cable was disconnected. It looked like there had been a coupler or perhaps a splitter in-between at some point in the past, as both sides of the cable already had proper ends crimped on them.
Well, I didn't have any couplers or splitters that I could use to join those coax cables together. What I did have was a multitude of 75-ohm to 300-ohm converters, like what you would use to hook up coax cable to a really old TV that only had rabbit-ear connectors. I took two of them and taped the 300-ohm ends together to essentially create a coupler for the two coax cables. It worked great.
Later that day a guy in a truck stopped near our house and hopped out holding an instrument in the air that looked like something from Ghostbusters. He gradually made his way over to, and found my improvised adapter. Apparently my adapter was causing frequencies that were supposed to be isolated within the closed cable-TV network to be inadvertently broadcasted into the airwaves, causing some kind of interference with other local broadcast/communication frequencies. The guy was nice, switched it out for a proper coupler and left.
