Another twist on storing screws when removing them is to have an old egg carton handy. Just place the lid screws in the first cup, the next set of screws removed in the next cup and so on. When putting the unit back together, reverse the order.
I don't know if there is a standard for this,but when I'm using zip-cord,my practice has been to use the lead with the molded-in tracer as the positive:
''If it's got something on it,it's got something on it''
I fry naked. Makes me feel alive.![]()
I use one, too--they are fantastic. A no-brainer.Magnetic dish to hold all screws and nuts removed. If I don’t use the dish a few screws or nuts will never be found. Just like the missing stocks thet get lost in the dryer.
I used to do that--don't know why I stopped. Muffin tins work, too, and are harder to knock over if you're clumsy like me.Another twist on storing screws when removing them is to have an old egg carton handy. Just place the lid screws in the first cup, the next set of screws removed in the next cup and so on. When putting the unit back together, reverse the order.
Way more organized than me! I bet you fold your socks, too.I often (masking) tape screws, nuts, washers, even removed components, to sheets of A4 paper, making any relevant notes or diagrams next to them. The pages are numbered as I make them, and filed in a zip-lock bag until needed - there's never any doubt as to what goes where, even months later.
With the pages numbered, the exact reassembly sequence is obvious as well - just the reverse of removal.
funny you just say this as i just bought a nice kit to fix my own teeth but cant do it so thought best use is for electronics repair toolsHere's another one: ever try to read the value on an old cap in a densely populated board? Often, the side you need to read is facing away from you and you cannot get your head near the far side because---well, if I have to explain further then this has never happened to you. Anyway, I bought a small, angled dental mirror (about $5 on Amazon) so I can read the "far side" of caps.
I started having a hard time lifting the arm at the end of an LP.
Got harder every day. Also got to be 74 last Oct. So I says say I, How about a little help. Finally fixed the problem by putting an eye bolt (1/4") into the ceiling at 2 spots.
I then ran up some carpenters nylon string that started around 2 feet from the arm at the ceiling. Then it went over to another eye directly over the arm. The carpenters string was super flexible but not enough. It sort of looked like it was pulling. So to solve that, I made the last 12" of string going to the arm a piece of .006 fish line which is super flexible and offered no resistance. It all works nice now. I can easily lift the arm with no pop at the lift. Am I brilliant or what?
Don't solder in your underwear.![]()
Ha ha! I love it! Good for you, man! Anything to make the music happen!Here are some photos of my tone arm lift. Enjoy.....View attachment 1216284 View attachment 1216286 View attachment 1216287
That is brilliant! Why the hell didn't I think of that? I can't wait to try that.If you need to solder two wires together and don't have "third hand" you can use an old plastic spray can lid. Cut a notch in each side and place wires in notchs. Solder.
