probably depends on the state of things when you start. If the caps weren't bad to begin with, you won't notice much change, and despite common wisdom, they aren't always bad. On the occasion I feel motivated to do it, its usually because its giving me some other issue, and I tend to apply a bit of a scorched earth policy to repairs. The last several repairs were not capacitor-related failures though. Bum transistors causing noise was the issue, but I did the caps as part of the half century maintenance routine. Both units work fine, and arguably better than before I started but I won't honestly tell you that it was all because of the caps.
