FavoriteFrog
Hello all, long time lurker first time poster.
I have a 1975 Zenith Allegro Quad that i'm attempting to get some External Speakers on.
(Chassis 15WFR51)
Setup: Zenith Record Console EXT Speaker RCA out's -> 100ft RCA -> Aiyima A08 Pro Amp -> Bose 301 Series 2.
Issue: When the EXT RCA (L) channel is plugged into the Aiyima A08 amp, the volume is about 10% and very tinny. HOWEVER, when i plug the EXT RCA (R) Channel into the record console, then PRESS the hot pin of the RCA (R) to the outer ground sleeve of the RCA (L) plugged into the Aiyima amp the sound gets near perfect while that connection is made. If i plug the RCA (R) channel into the Aiyima AMP the RCA (L) goes back to being 10% again. The Right Channel operates perfectly on its own with no concerns. The Record Console itself has no issue between L+R Internal speakers so i have isolated this to the EXT RCA Ports.
Troubleshooting: I have verified both Channels of the Aiyima AMP, Verified both Strands of the RCA (Both done using the (Right EXT Channel) and had no issues.
Additional Info. I also attempted to directly ground the EXT RCA (L) Port on the console to a common grounding solder point and that did not change the issue. I also tested the 1/4'' Headphone out via a 1/4'' to RCA dual adapter and had No issues at all. For refrence the 1/4'' Headphone port is wired FIRST then goes to an internal switch terminal before a single wire is soldered to the EXT RCA (L) port.
Anybody have any ideas on what i could try next?
(Chassis 15WFR51)
