Hello!
Restoring a big ol' Zenith console and ran into an issue.
Had just finished putting her all back together when all of the sudden I realized the unit had not completed it's automatic cycle and would not start again or return/reset.
I pulled the table out and saw what had happened.
A little articulating plastic piece broke off of this clip that makes contact with this metal lever that let's the table know the cycle is complete. This means around 80% of the time it's where it needs to be but sometimes it moves out of place.
All I need to know is how should the clip piece be positioned?
I have 3d printed a replacement because I plan to retrofit some kind of little piece that kind of lets it be/move when it needs to but doesn't let it get out of place (like that little articulating arm did).
Can anybody help me picture how this should look or so I can come up with something?
I have attached pictures of the lever it must touch by the camgear and the clips and it's position on the camgear I am referring to.
And also a picture of the broken articulating arm + one pulled from another unit that was beyond repair I had around for example.
Thank you all!
Thank you all!
