Russellc
Addicted Member
What advantage is there to time alignment if the waveguide is on top of the box?
Unless the woofer is very close to the top edge of the box like the DQ-10 I would still recommend placing the waveguide in the box for permanent installations to reduce the center to center distance. The discussion of crossover nulls clearly shows the advantages of a compact configuration.
It can obviously be slid forwards and backwards, big help with the QSC which is considerably longer than the standard waveguide. In the discussions about the QSC both here and on Augerpros build, the delay which occurs because of the physical displacement of the drivers due to the longer length is a problem...it can be adjusted for by letting the waveguide hang over the edge out front a little.
Jack is trying to cure same problem via the LR crossover.
Basically the same thing Altec did with the A7's horn on top, sliding it back to align the AC of the HF driver with the LF driver, unless it was mounted inside the box, then Altec just suggested reversing the phase on the HF driver, similar to what has happened here.
When afixed to the front baffle, unless delayed electrically or, as some have done, putting the waveguide on the outside of the baffle, and the woofer mounted from the inside....(just another way of shortening the difference in distance) there is a time delay problem due to lack of alignment. Top mounting allows a little "adjustment" by physically moving the waveguide/driver assembly while the plane of the woofer stays still....couldnt be done when mounted to the face plate.
The other advantage you are not thinking of IS with the "overhang" as both I and Zilch have done, it puts the horn much closer to the woofer, again something that cant be done with it mounted to the face plate. I have been doing this awhile, and wouldnt have said it if it wasnt true! A pic will make this more clear, I'll attach one when I get home, and you'll see what I mean. Allows the horn edge to stick out past the plane of the baffle, which places it closer than baffle mounting will allow, due to the large physical size of the QSC horn. Have you aquired one yet? Yes there is an improvement in the nulls by placing the horn closer to the woofer, this is precisely why I did it, I think it will be more clear to you when you see a pic of the arrangement. Mounting the QSC in the face plate has it FURTHER from the woofer, due to the size of the QSC guide.
The length problem could be addressed (to some extent) like JBL did the 4430, putting a 1 inch spacer on the front baffle underneath the horn, but this wouldnt get the QSC any closer to the woofer.
Also, one can always replace the baffle as many here are doing, and move the woofer to the top. fortunately, my JBL 4507 boxes position the woofer high already! Or turn the box on its side, for that matter.
Russellc
