At last the OLAs are EWaves!
I hope everyone will forgive a long first post, but I thought a few notes on my Original Large Advent (OLA) to EWave conversion might help someone -- and I'm pleased to have gotten through the project!
I'm truly sad to have arrived here just after the passing of Zilch, who seemed a true village elder in the best sense: wise, tolerant, learning and teaching abundantly. It was only after I started to read through the EWave threads here and
at AudioHeritage that I realized how much thought, research, and discussion went into the deceptively simple EWave design, and I'm sorry not to be able to thank him for that. But I do want to thank all the other EWavers, and especially Bauhausler, whose
OLA conversion guide steered me past several potential land mines.
I've had a pair of OLAs in storage for longer than I can remember, and I finally put new surrounds on the woofers. The surrounds were from Parts Express and apparently are the narrower type that can raise the woofers' resonant frequency to 40+ Hz, but the space between the masonite ring and the cone seems too small to take anything wider, and they sound very good to me after the repair. (I'll post a set of measurements before and after the EWave conversion when I get the data entered.) The speakers are unmatched -- one has a dark front panel, the other a light one -- but they both have masonite-ringed woofers and sounded similar to me before and after the conversion. They have "utility" cabinets that I plan to refinish with "Band-It" cherry paper-backed veneer.
I wasn't sure if the EWave circuit boards were available, but I had an ancient Radio Shack DIY circuit-board kit sitting around anyway, so I made a template from posted photographs of the board, simplified it slightly by eliminating the jumpers for bi-amping, and as the Radio Shack boards were a little smaller than Zilch's I moved the iron-core coil off the board to the other side of the big capacitor. Whether from corrosion over time or insufficient time in the etching solution, one board conducted between the "islands," but some crude work with a Dremel routing bit solved that problem.
The opening in the OLA's back for the terminals and the high-frequency control is about 3" (7 cm or so) square, so I decided, like Bauhausler, to put the binding posts and the L-pad control into it without further cutting into the thick particle board. It's a squeeze, but it fits. I thought the wires would probably lead upward so I put the posts over the L-pad knob, but that may have been a poor call. Given the space constraints, I should have ignored the instructions that came with the binding posts, which said to align the posts so the wire holes run top-to-bottom. Side-to-side would have been easier to thread. I'll wire up double-banana-post connectors to the speaker leads when I install the speakers, though, so it won't matter.
The circuit board construction was the most time-consuming part of the project, but (as can be seen from the photos) I'm no wizard with a soldering iron, much less a master board-etcher. To my surprise and delight, the boards worked fine without any resoldering. Getting them mounted with the proper clearance for the nuts that connect the binding posts electrically as well as mechanically to the board took a little experimenting, but after shimming things with a scrap venetian-blind slat and moving the L-pad (which I'd put so close to the board that it couldn't be mounted) it all worked out.
Using Bauhausler's invaluable measurements as a guide I hacked away at the cabinet with a hand-held jig saw and, when I broke my last blade, a hole-cutting drill bit, a hand-held rotary saw, a Dremel cut-off wheel, a sanding bit, and a hammer. It was not elegant carpentry, but the Polk Audio horn fit well and with a little Mortite rope caulk I got a good seal. I didn't add a foam plug to the horn as he suggests, but my high-end hearing isn't what it used to be, so I don't mind a little high-treble emphasis. I attached the crossover board to the back of the cabinet with Amazing Goop Wood Contact Cement and added a couple of wood screws for good measure. (Hint: it's easier to remove the old controls by chiseling from the back than by trying to lift the staples from inside.)
Following the instructions that came with the Selenium compression driver, I attached the supplied clips to the high-frequency leads from the crossover. I tried that for one woofer as well, but by the time I desoldered and cleaned the woofer terminals and got the clips soldered to the low-frequency leads I decided it just wasn't worth it. I just attached the woofer's black (negative) and green (positive) leads to my crossover leads with the little wire binders (what
are they called?) that I salvaged from the original crossover assembly. Bauhausler recommends adding stuffing to the original ration of fiberglass that is in the OLAs, but with one speaker I simply couldn't fit any without compressing it to the point where I think it would have hindered the movement of the woofer cone. I added a third of a bag of Parts Express nylon fill into the other. I don't hear a difference, but I'll have to measure that one and compare it with my numbers from the first one.
The result: the speakers sound dramatically good to me, with what I'd describe as smooth, deep bass and very clear midrange and high frequencies. As I said, I've taken some measurements (with my extra-high-end $20 eBay old-type RadioShack sound meter, model 33-2050) and I'll try to get them up soon after I adjust for its nonlinearities and make some charts. I've found a new favorite test record, too: Philip Glass'
soundtrack for Martin Scorcese's Kundrun. It's got both acoustic and electronic music, Western and Tibetan instruments and chants intermixed, and an incredible range of sounds, from deep drums to tiny bells. It sounds great on the Econowaves. I hope my neighbors forgive me.
